Engine management light!
Hi Guys
I have a 2006 xkr. Yesterday after work i started the car and nooooo engine management light stayed on. I turned it off then on then off. In the desperate hope that it would fix itself It didn't of coarse, so its booked in to be diagnosed on Thursday.
There is no loss of performance, everything seems to be doing what it's supposed to be doing. Apart from that damn light all seems fine.
Anyone had this happen? and what was the outcome.
Will let you know what fault codes come up on Thursday.....fingers crossed nothing too major.
Just back from getting the codes read. Turns out it was the EGR valve that caused the fault code. May have just bee a bit of crap in there. Anyway they cleared the code and all is good once again. If it comes back on again may see if the valve can be cleaned or may replace it. Does anyone think putting a fuel cleaner through may help?
