Erratic Rpm
Erratic Rpm
Yesterday I was approaching the freeway and had to fully accelerate in order to avoid an oncoming vehicle. The XK downshifted into “passing gear” and after I noticed that the engine RPM was somewhat erratic. Specifically, the RPM was indexing, for a brief period, before it settled down.
Anyone out there had this experience?
3 thoughts in no particular order. Rev. limiter, MAF or Oxygen sensors. If as you state, you had 1 down shift while merging, rev. limiter not likely but I would definitely check out the other two. If they all check out you may want to look at the fuel filter.
You did not state the milage on your car.
So your elevation should not be an issue. At higher elevations the oxygen and pressure levels are different and requires adjustments for ignition - sometimes these corrections are sluggish - that was my line of thinking. I thought since you were in Nevada you may be at a high elevation.
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
