Error Code U0155
Does it come back if the code is cleared, i.e is this a 'solid' fault? Also, have you had any other issues? When the car starts throwing up an assortment of odd faults that mysteriously clear themselves, the problem is often low charge in the battery - the XK draws a lot of power as it wakes up.
The instrument cluster has more than just dials in it; there's quite a few functions controlled by the module in there. If the fault keeps occurring, the module might be faulty, it may have had a software glitch and need resetting, or it might be a bad connector or frayed wire. Unfortunately, the diagnostic procedure requires the Jag diagnostic system, so you'll need a jag specialist to dig into it.
The light first appeared today as I was updating the navigation. It stays on solid. I will see if it clears overnight, but not sure how to clear it myself. Unfortunately, there are no Jaguar dealers in my area, but there are two garages that specialize in Jag's, so if I cannot clear it or if it does not go away, I will have to take it in.
I did turn on the ignition during the install and got a bunch of error messages like, battery not charging and transmission fault. After a few minutes, I restarted and they all went away except for the U0155. How would I clear this myself?
I believe you can clear codes using generic OBDII readers, but I've never done it myself.
The Nav install takes a long time, during which the car is sucking juice at over 10 amps as it always does in 'convenience' mode (the powered-up-but-not-running state it goes into when it's unlocked). I think you've just drained the battery - take the car for a decent run to charge it up (I assume it will run with the code active), and see if the code clears itself. Also, I believe some codes are cleared automatically after a number of trouble-free starts.
KarimPA
09-27-2015 08:46 AM
