Error codes - 2007 XKR
I'm down in FL, Jag is up in IL with driver I hired to bring it down. He put Harbor Freight code reader on it after Check Engine light came on. Errors: $7E8: Engine and $7E9: A/T. No submenus available. Has anyone dealt with these before? DIY or have it hauled to dealer? Many thanks, Mike
$7E8 and the $7E9 are fuel/ air intake codes, as for the P1326. This code is set when the knock sensor detects vibrations from engine rod knock, however, it may be set falsely due to incorrect knock sensor logic programming in the engine control module.
Harbor Freight code reader???
I'd thing it'd have the 'normal' P0-type codes.
I'd think those codes would indicate LEAN FUEL CONDITION BANK ONE and LEAN FUEL CONDITION BANK TWO. Also probably a LEAN FUEL CONDITION, as a general for both sides.
Those two would probably mean a Vacuum Leak somewhere.
I'd say have dude bring it to an Autozone or O'Reilley or some other parts place and have the real codes pulled.
I'd also say that probably there's a vacuum leak, and it'd probably be somewhere towards the area where the throttle body is located.
LoganWolf
05-09-2012 04:49 AM
