Ever seen this brake caliper?
The following 2 users liked this post by Cambo:
mosesbotbol (05-13-2020),
patpayne (05-13-2020)
Received 3,229 Likes
Here ya go, exact same brakes and caliper stickers as yours: https://www.ebay.com/itm/Set-of-6-x-...KzVkAASJ1Qscww
Clean and repaint the calipers, not difficult, then whack the stickers on, good as new!
Received 1,130 Likes
The brembos on my xjr were grey and I purposely avoided the urge to paint them yellow or red. Mind you I had to wash them often.
I guess when I get back, red is out, grey is in.
The following 3 users liked this post by Stuart S:
Don't get me wrong, I have them too and they're great, but I am not looking forward to rebuilding them when 1 or more of those pistons starts seizing up.
And do we really get any more stopping power than the stock 'R' calipers??
Nope, they're still good. When the time comes, I already have a set of 4 replacement rotors. I bought them on sale (thanks to JAHummer) in November 2016 at a total cost delivered overnight of $466.16 (2 front@$132.99, 2 rear@$100.09) and put them away as spares. I saved more than $1,700 over Jaguar dealer list prices.
For details, see: https://www.jaguarforums.com/forum/x...-cheap-171582/
Mate you seem to be in the know, just purchased an xkr and the dealer had the rotors replaced, said they were down 2mm.
This car had only 28ks on it. You think it may have got a "floggin"? What brand do you think has best wear capacity?
I got a tojo 400k plus, only two sets of pads no rotors.
Mick.
Mick.
Mick.
Mick.
Modern Jags especially the more high performance R versions are very hard on the rotors and pads, as both are fairly "soft" (JLR say this improves brake performance and feel but I'm not so sure), so they wear out pretty damn fast especially the rears.
The minimum thickness specs for both the pads and the rotors are ridiculously conservative, especially the rotor spec of 2 mm less than new thickness.(it's the same on all modern Jag rotors regardless of size, except for the carbon ceramics which go by weight).
2 mm, they can't be serious! (but they are). I believe it's a ploy to sucker the punter into very expensive rotor and pad replacement at the dealership.
There are heaps of after-market rotors and pads out there that wear much slower than the OEMs, make less noise, are smoother and more progressive, and give off waaaaay less dust.
Yes with some you may sacrifice a little in ultimate braking performance but unless you are tracking the car you would never know.
They are also a helluva lot cheaper than new OEM.
Last but not least it's a very easy DIY saving you heaps of labour cost.
I guess you might be asking me instead of Stuart S so if I am correct here is my view:
I'm getting on in years so i'm more a straight burner today but still like to "hoon"around the mountain on occasion.My F-Pace is awd and i feel much more
comfortable in it. Back to the brakes, your recommendation for after market make. These on it are 380mm x 376mm. Would 400x380 or 376mm be the go?
I worked on all my own gear till computers. still did the basics after warranty period though.
Thanks Mick.
Yeah i was mate but i'm as dumb as a bag of rocks when it comes to this.
Thanks Mick.
Thanks Mick.
If you stick with 380 and 376 there is a large range of rotors to choose from as they are identical across the range, no need to specify XKR.
Just search eBay and eBay Motors for "Jaguar XFR brake rotors" and you will get hundreds of hits including Hart, R1 Concepts, Stop Tech and Power Sport.
From my research and looking at the pics in the ads I am fairly convinced they are pretty much all the same and are all made in China.
That's not necessarily a bad thing, I have been running a set of Hart drilled and slotted for over 6 years now on my XFR and then F-Type and they have been great.
It's not quite so simple with the pads.
The front 380 mm pads are identical across the Jag range but not so the rear 376 mm pads. On at least the F-Type they are very different to the XFR and XKR pads and I believe earlier XJR's. I'm not sure about the later model XKR (X150), I think it has the same pads as the XFR but I am not sure. It all depends on the EPB set-up, if your XKR has a single central EPB motor running two cables one to each side then you can use XFR pads but if it has separate EPB motors one on each rear caliper (like the F-Type) then you need different pads.
If you upgrade to 400 mm front and 380(?) mm rear rotors such as the Alcons then you will also need new calipers, caliper brackets and splash shield which would get real expensive real fast, you can't use the bigger rotors with the OEM 380/376 calipers and pads.
The 380 mm front 376 mm rear combo is very common on modern Jags, the F-Type R, XFR, XJR and XKR all have that combo.
Mick.
