Exhaust leak?
what year and model is your car?
It's not unusual for the joins in an exhaust system to not be 100% sealed which means that water inevitably drips out when the system is cold. You can either ignore it or try tightening the clamp a little. If the water is dripping through a hole in the exhaust system itself, then the structure has corroded and you probably need a new part or some bodging with exhaust tape.
Richard
Richard
peniole
01-22-2010 11:01 PM
