Exhaust upgrade
Hi Guys
Sorry if this has been asked already. Wasn't able to find info.
I want to change my exhaust system to one that will give my xkr a better exhaust note.........want to make her growl!! Who has done a mod to their xkr and what did you do. I am thinking about buying a complete system say Miltek and shipping it out to NZ. Any advice greatly received. .......Cheers
I just made a custom cat-back exhaust. I removed all the small piping and used bigger piping and resonators. I kept the factory cats, and I even removed the muffler, so no more active exhaust. I replaced the muffler with two extra resonators. The sound is exquisite without being too loud. Not too much drone also. Good luck...
From what i have found out so far Miltek and Quicksilver seem to be the main players for the xkr.
DJ i am looking into a custom system. Something along the lines of the Quicksilver system.
They have a centre muffler only. Does removing the active gear from the rear muffler cause any fault codes to pop up? What did you do about the piping etc back there? cheers.
I started at the cats and removed everything. I then remade new pipes with a larger diameter. I put 2 new resonators on each line (4) and removed the muffler. I added 2 more smaller resonators where the muffler used to be to deepen the sound. I just sealed up the vacuum hoses that were used to power the active exhaust on the oem muffler. No warning lights or anything weird by doing so. I added quad black chrome pipes for a nice finish. Sounds great with or without those extra 2 resonators but I'm picky...
Before spending for an new exhaust system, you might want to try removing fuse 19 and see if that exhaust note tickles your fancy (wherever that may be!). With fuse 19 removed, the muffler valves remain in the open position. Very easy to do. See this post: https://www.jaguarforums.com/forum/x...se-19-a-62736/
Stuart
I started at the cats and removed everything. I then remade new pipes with a larger diameter. I put 2 new resonators on each line (4) and removed the muffler. I added 2 more smaller resonators where the muffler used to be to deepen the sound. I just sealed up the vacuum hoses that were used to power the active exhaust on the oem muffler. No warning lights or anything weird by doing so. I added quad black chrome pipes for a nice finish. Sounds great with or without those extra 2 resonators but I'm picky... ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
Code:
Do a search for Milltek Cats and you'll find a sound clip of my set up with b/4 and after.
Stock exhaust, Milltek Cats and pulled fuse 19; No fault codes.
The nice thing about doing the Cats only is I can still activate or deactivate the active exhaust by removing/replacing fuse 19.
I may only change out the tips now for an improved look flling in the rear apron.
So are the first two resonators at the same locations along the pipe as the old center muffler and before axle mufflers? And a third resonator where the backbox used to be? As in:
Brand and model number of the resonators?
Code:
Your diagram is correct. I used magnaflow resonators 2.5 x 14 inches for the first two and used smaller no name stainless resonators for the rear. Really sounds good, I'll get a pic and sound clip real soon. BTW, I'm wondering how removing a fuse could open up the exhausts full time. The active exhaust seems like its only vacuum hoses that response to throttle pressure and/or rpm... Not sure what a fuse would power in this case??
plums (10-26-2012)
Yes, I pulled fuse 19 and yes it makes a noticeable difference. I've been driving without fuse 19 for over a year and never had the check engine light or any other faults displayed.
Keep in mind that the XKR was designed to be a proper British gentleman's sporting car and, as such, a raucous exhaust in the city would be rude and unacceptable. But, as a serious performance machine, R owners expect maximium power and a corresponding exhaust note. Hence, the active exhaust and split personality.
The typical brash Yank is the opposite of the reserved Brit. That's why we Yanks pull fuse 19. Looks like Kiwis are more like Yanks. Even if you pull fuse 19, you can still sound civil if you wish. Just drive like there's a raw egg between your right foot and the "exhilarator" pedal.
I prefer the exhaust note without fuse 19 and won't put it back any time soon. It adds to the thrill I get every time I drive my XKR.
Try it; if you don't like it, it's easy enought to put back. Let us know what you think.
Stuart
For details, click on this link: https://www.jaguarforums.com/forum/x...se-19-a-62736/ and see posts #7 and #10. Very easy to do.
Normally aspirated 4.2L XKs have a "semi-active" exhaust that opens and closes the bypass valve/flap depending on exhaust back pressure. That bypass is controlled mechanically by exhaust back pressure, and not electrically, so fuse 19 does not apply.
Stuart
if you are looking for a great sound on a budget... $200 at a shop
I removed both of the center resonators, and installed an X-pipe. I then put in a switch to control fuse 19
when open, the sound is what you would expect from a car like ours. aggressive and exotic. I would say over all 30-50% louder than stock
When closed it is quite. no noticeable change from stock
Open and close, i hear no drone. then again, i did not notice the drone before any changes either...
When i get some free time, i will see about recording a sound clip.
