Exploding Spark Plug & Destroyed Cylinder
The piston hitting the plug directly is all but impossible, the plug is fixed, the piston stroke is fixed.
The only thing in the cylinder which can contact a piston is one or more of the valves.
Or a foreign object that made it's way into the cylinder somehow, like a bolt dropped in there while the sparkplug was out.
Not a chance that the sparkplug "exploded" on it's own.
Something else was loose in the cylinder and got between the sparkplug and the piston top.
OK, I think the shop is full of crap but we need to move forward and see the extent of the damage. Use a bore scope to inspect the cylinders / valves etc. through the spark plug hole. You should be able to see valve impact marks on the piston tops of all the cylinders on that bank if a cam is out of time.
Personally I'm going with FOD got down the plug hole and then banged around. Hard to say if they didn't drop the plug and shattered the core without realizing it, then troubleshot the cylinder miss until the plug fell apart and got worse. Or somehow a chunk of metal got down there. Also if your bore scope results only show valve to piston damage in one cylinder then 'something' held the valve open and the piston whacked it, most likely bending that valve.
That's a ton of damage and I suspect the piston top is pretty beat up as well. Notice this picture evidence of my dad's accidental 'losing' a 5/16" carb mounting nut on a Chevy 350 in his boat...
![](https://i188.photobucket.com/albums/z291/Ranchero50/Boat/Chris%20Craft%20280/DSCF0936.jpg~original)
So, moving forward to troubleshoot. Inspect each bore and if they look clear, have them do a compression check on all 8 bores. That'll show if you have a bent valve and won't cause further damage. If you have low compression it's coming apart. Note which ones are low so they can concentrate on the problem bores. If the compression is good the only specter you have is rod bearing damage and it's difficult to troubleshoot without taking it apart. I'd consider putting the plugs in and firing it up. You'll hear the loose bearing if it's damaged.
Received 2,626 Likes
Oh they can explode.... Its rare but it can happen. If spark plugs are faulty from factory, they can work for even a year before they explode. Trust me i have seen this happen.. Adnt there wil be pieces all over the cylinder. You just have to hope that pistons and other bits are fine... When mine exploded, it broke the coil pack at the same time..
Guys you do realize this is a 5 year old thread. I have seen the plugs blown out of the head, as stated due to weak or damaged threads, and I have seen the porcelain centers blown out. from crappy manufacturing, and not withstanding the pressures of combustion. I have been working on everything from 14,000 RPM motorcycles to Ferraris, Lamborghini's, Maserati's, Jags, Hot Rods, and 10,000 HP dragsters, and everything in between over the last 50+ years. Spark Plugs Don't Explode! Spark plugs get damaged by "Something" introduced into the Cylinder! Whether that is something dropped into the plug hole, or something dropped into the intake tract / carburetor, that causes mechanical damage, or by improper valve timing, which causes bent, and broken valves. Which can damage the end of the plug, such as seen in the pics at the beginning of this thread. But the Spark Plug itself Exploding is a load of BS. It simply doesn't happen, and if someone tells you it does. They are for whatever reason, trying to cover up the real cause of the damage.
Jack
Jack
RedRider48 (03-23-2022)
#30
Anybody ever heard of this happening.
My 2007 XKR (60,000m) is in the workshop here in Singapore. Its coming up to its 10th birthday and as such its 10 year license will expire and its going to be deregistered and Im exporting it back home to UK to keep my XJR company.
It had a small oil leak at last service and while that was being fixed I used the opportunity to replace a bunch of items (water pump, timing belts, tensioners, chain etc). All that was done by the independent specialist here and when they fired it up again the spark plug (all new) exploded and has destroyed the piston, valves and god knows what else) of the first cylinder. Im looking at a replacement engine or rebuild (if possible). Im in shock, it went in to fix an oil leak and do some sensible engine preventative maintenance and its now F$&/@D ... has anyone heard of exploding plugs destroying a cylinder before ???
So, singaporecat, 5 years later, what was the result?
Cee Jay (03-23-2022)
#31
After some negotiation they accepted the responsibility, the car was due to be exported to the UK 6 weeks before the incident, this still happened, as a 'non-runner' though, which saved me some import tax as the value was reduced. The shop ordered me a brand new engine from Germany which was shipped to me UK Jag specialist that fitted it all for me. Its been working fine ever since back home in UK.
The following 10 users liked this post by Singapore Cat:
007XKR (03-29-2022),
89 Jacobra (03-30-2022),
Hans Amstein (04-03-2022),
JonWat (03-30-2022),
kj07xk (03-29-2022),
and 5 others liked this post.
Lagonia
02-12-2022 11:18 PM
JX350
11-06-2018 09:53 AM
