F type subframe
Privilegedjaguar (06-11-2022)
Panthro (05-21-2022)
Received 1,122 Likes
Cee Jay (05-21-2022)
A typical cause of oversteer might be a loss of traction on the rear with resultant sideways slip that points the car toward the center of the turn/circle.
A reduction of frontmost mass would not seem to correct that situation.
Reduced overall mass: lighter weight, reduced stopping distance, improved fuel economy, faster acceleration. That's good enough for me.
Panthro (05-23-2022)
I understand "oversteer" to be where the car responds with a tighter circle or smaller turning radius than the driver input intends.
Panthro (06-12-2022)
You invested a lot of time speculating that the aluminum F-Type subframe would bolt onto your XK. You took measurements, made a sketch and shared.
So, maybe you thought it unkind of me to question your comment about front-end weight reduction affecting "oversteer".
If so, I apologize. No harm meant.
However, inquiring minds and readers of your thread want to know: would you be so kind as to explain your definition of "oversteer" and how the proposed frontmost weight reduction would affect vehicle dynamics, specifically oversteer?
PS: I do agree that an overall/general weight reduction is a good thing.
Best regards,
Bill
Panthro (06-13-2022)
#30
#31
The following 3 users liked this post by steve_k_xk:
#33
I'm in need of a replacement subframe (due to heavy corrosion), and if the f type subframe is a straight swap with no alteration needed (i.e all control arms fitting at the right spots) it might well be the path I will follow.
The following 2 users liked this post by Schecter1992:
Panthro (11-11-2023),
steve_k_xk (10-30-2023)
#36
steve_k_xk (11-12-2023)
Jaguar Forums Editor
11-29-2012 01:38 PM
jagxkrtoofast
10-01-2012 07:55 AM
