F Type wheels on a 2009 XK
Would these Propeller wheels fit on my 2009 XK? The tire size is the same as my stock 19”.
Not sure about the offset being correct.
would the TPM’s in the wheels, work, or does something have to be recalibrated?
Front: 8.5"x19" offset 49mm 245/40 ZR19
Rear: 9"x19" offset 27mm 275/35 ZR19
John
John
I just went through the exact same scenario and questions for my 2008 XK as I was going to purchase F-Type Centrifuge Wheels. Although I didn't wind up purchasing them, I learned that they should have fit nicely with similar offsets.
Steve's input was very helpful. You can look up my recent thread about it with the information.
steve_k_xk (05-23-2023)
btw, is yours a dark blue convertible? I may have past you on Sellersville road, a while back.
We will have to touch base, regarding service shops etc.
John
Funny, I was going to ask you the same thing about service shops in case I was ever in need.
Unfortunately no! I haven't had any issues with the XK over the year that I've had it, other than resetting the passenger seat, which I did myself. No issues with the XF either, though I did have a local Jaguar "shop" on York Rd recommend a tire rotation and front end alignment due to uneven tire wear, as well as reporting the rotors were pitted and rusty. None of which were valid; the tech reported all tires abnormally worn and in need of rotation - his measurement showed 7/32 tread depth on all four tires; front pad thickness as 6mm, rears 4mm. Having said all this, I may need an alignment as I hit a pothole and managed to destroy both right side tires, so if you have an alignment shop you trust, I'll check them out
