Falling headliner
It was falling pretty bad so I decided to pull it down. I've never done anything like this before so I was a bit intimidated.
Getting the trim on the sides was a pain. I found it easiest to pop them all out and leave them in place. Then get the middle piece on both sides out. Took off the sun visors and light cluster fairly easy with the right tools.
Cleaned the old felt best as I could. Then I tossed it in the wash on delicate, tap cold, with a teaspoon of soap. The foam board was another story. I scraped that thing as best as I could. The stuff got everywhere, so do it somewhere easy to clean. I found a plastic ruler worked great because it's flexible and long, until I found a car brush. I got the bulk off with the ruler, then the brush got pretty much everything else. I was left with a tacky surface, which is actually ideal.
After letting the newly washed headliner bask in the sun on my patio table for an hour or two it was completely dry. I flipped it a few times. I wanted to lay it flat to avoid potential stretching. I dont' know anything about fabric.
I must have done a dozen test fits before the final. With the tacky surface it's great for testing, you can just press the fabric on and it stays. First I started in the middle and worked my way out. Couldnt' get it centered for the life of me. Then I started from the outside perimiter and worked my way in. What worked very well is from every hole to it's opposing side I worked it in. I was mostly doing it for practice towards the end, I knew I'd have one shot when I put glue down. I ended up using 3M light fabric adhesive in a spray can. I sprayed it in the empty garage and got a good coating, then went inside to the dining room table. Using a 3" paint roller with the fluffiest rolling pad I could find, I attached my perimiter. I did the visor areas by hand and pressed in hte corners as best as I could.
Then I started working my way toward the center. I did about 3" perimiter all the way around, then another 3", then another 3". I went over everything a dozen times with the roller. On stuborn parts I just held it there for 5-10 seconds, and it stayed.
Overall it was a pain, but it's all back in and looks fantastic. I couldn't be happier.
![Falling headliner-af3znxmh.jpg](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/225190d1683066685t-falling-headliner-af3znxmh.jpg)
![Falling headliner-8hbshlhh.jpg](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/225191d1683066685t-falling-headliner-8hbshlhh.jpg)
![Falling headliner-amul3sch.jpg](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/225192d1683066685t-falling-headliner-amul3sch.jpg)
The following 4 users liked this post by nasomi:
Nice job!!! I did the same thing a couple months ago... https://www.jaguarforums.com/forum/x...urbish-220369/
Did you wash your headliner? I had a massive amount of crud that was on the headliner, all very sticky. I'm amazed that the wash got it out so well. I actually broke one of the plastic pieces on the passenger side that the middle piece slides into. Fortunately once it was back together it was completely hidden and didn't affect it being pinned back up. I may take the pillars off and re-glue them, there are a few places that they're wrinkled, now with the head liner all nice and tight i notice it more.
Labor is cheap here in FL. A shop in West Palm Beach, one recommended on this forum, did the whole job and the side trim for $400. New foam using the original Alcantara, which was usable as it had just begun to drop.
Crazy thing was, the other cars they were doing included two Bentley's and a McClaren. First world problems.
Remember that there is a better quality synthetic suede available at under $5.00/running yard X60" width. So, if you don't want to mess with cleaning or washing the Alcantara, I have access to buying it wholesale at about $5.00/yd. In other words for about ten bucks, you can have all new material. I have shipped it to many forum members without a single negative comment.
110reef (09-20-2019)
The following 2 users liked this post by nasomi:
tberg (09-20-2019),
TexasTraveler (09-20-2019)
