fan comes on from cold start
car not been used for weeks or turned over , so decided today to turn over the engine let it idle for 20 mins . as soon as i started it the fan came on quite loud and stayed on even when i turned of the engine it continued to run for 30secs . i let it cool for a few hrs then turned ignition on tonite but not engine yip fan came on straight away. any ideas?
George05 (01-03-2020)
Thanks Q&C i will put scanner on car over weekend see if it picks up any codes . as you know i changed out the water pump a couple year back , first thoughts was its gone. did not have the time to give the jag a check over today but coolant level was normal . my thoughts are thermostat faulty, or relay sensor etc or could be just a worn wire . been on the web to me its on them lines but stand to be corrected
Went out to car today key fob in pocket , i pull the drivers door open , Fan starts up . so a short some were not even sat in seat never mind pressed any thing , fan came on and off a few times i hooked up the i carsoft V11 i had bought last year its picking up code P0481 control circuit/cooling fan2 mal function , thinking now must be a worn wire as it came on and i had only open the car door lol also picking up another code P1603 drivers seat lumbar support sensor i never knew about that one . Will book it into indy
Queen and Country (01-04-2020)
update. out to car today tried changing fuse F31 in front fuse box . as soon as i opend door on comes the fan again . pulled the fuse it stops . old fuse looks ok but replaced it with new 10a fuse on comes fan again . pulled a few relays the large square ones fan still on only 2 rectangular shaped relays left . Pulled the first on left . fan goes off , put relay back in fans on again , pulled the other to the right fan goes off again , closed bonnet and fans still on without engine or ignition on , locked car via key fob . fan goes of . Got her indoors to follow me to indys left car their , he can fix at his leisure will update when i know whats wrong and fix
Queen and Country (01-05-2020)
https://www.jaguarforums.com/forum/x...10-xkr-144923/ seems to be common problem
George05 (01-06-2020)
https://www.jaguarforums.com/forum/x...solved-226311/ Another on the XE section
George05 (01-08-2020)
Result as such , in my case a worn wire as predicted by my indie who has been a jaguar guy for over 30 year , not had a look at car but i was dropped of soon afer garage called around 12 lunch time to pick up car , it cost 4hrs labour for them to trace problem and remove front bumper wire was located under that cant remember what side as events unfolded on way home . car drove really good it felt better than it went in . Well it felt that way . doing 70mph on a stretch of dual carriage way whilst over taking i hit a very large pot hole at least 3ft across and around 8 inch deep BANG tyre blew . instincts cut in and i put on hazard warning lights and veered from outside lane to emergency lane , tyre kaput and kink on inside of alloy . phoned a few nos and hour later a tyre fiter van came to my rescue with a new dunlop 255-35-20 tyre drove car home now shattered and deprived of green backs
![Icon Cry](https://www.jaguarforums.com/forum/images/smilies/icon_cry.gif)
George,
To offer some consolation when its pissing down on you.
It would have taken a great deal of plumbing misfortunes by a great many to pay for a Jaguar like that.
You are still ahead.
I bet the mechanic's 4 hour rate was lower than your minimum.
i am not a rich man QC took a lot of the Queens pounds after 30 years working for others to strike out on my own now a few year later can see through the rain clouds lol the indy owner is a client roses will spring again off for a cuddle with the cat of nine tails
Queen and Country (01-08-2020)
