Fasteners for XKR 4.2L Engine Cover C2P5448
#41
Just to give an update, the Land Rover screw PZM100060 is a couple of mm shorter than the original screw on the engine cover, but it works fine and the head of the screw looks identical to the original.
So it's an alternative. I put one on a car today.
Didn't try for the rubber grommet though.
panthera999 (12-30-2021)
#42
#43
I found this on Ebay and it fit,my 07 XKR engine cover. https://www.ebay.com/itm/254509097895
#46
Land Rover PZM100060
The shorter length can be overcome by pressing the receptacle clamp so that it is closer to valve cover bracket. The receptacles can be easily slide off to remove and simply pressed in vise. I
I also added nylon washers to each in order to retain the fasteners from getting lost in the future. Found 1/4 inch nylon flat washers at home improvement store. Just press them on to shaft. Oh...the only difference is the Land Rover fastener is a standard driver head not the phillips head.
Improvise - Adapt - Overcome
The following 2 users liked this post by Deabs:
Ipc838 (09-27-2024),
#47
Clips for cabin filter cover
