Fault Codes
Evening folks
Got 2 weird fault codes appear on my XKR
P0610 and P0630
Car isn't affected, drives fine, starts fine, changes gear fine.
Tried clearing the codes, but they reappeared. I did have the battery off while fitting something, and it was after I are attached the connectors these codes appeared.
Any help would be much appreciated
P0610 and P0630
Evening folks
P0610 and P0630
P0610 and P0630
The first question is what were you doing or fixing that you needed to remove the battery cables. Were you doing any electrical work or programming anything. I would be concerned with the P0630 as this one does not recognize the vin number of your car and could potentially prevent your car from starting.
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/956x272/screen_shot_06_07_19_at_08_29_pm_030d6b6e4363a56210cd318a2f1cf2464b5eb057.jpg)
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/956x236/screen_shot_06_07_19_at_08_29_pm_001_30efb11e9a48d881c8be21eb216a48cef946ebb7.jpg)
Someone did, or tried to, re-map the car in the past? Flash a different engine tune to the car?
In any case you will be rolling the dice trying to re-flash the PCM, CJB or RJB with an eBay or British Diagnostics crap SDD.
Personally, if the car starts, runs and drives fine, no errors on the dash, then I'd let sleeping dogs lie...
GGG (06-07-2019)
Received 1,975 Likes
steffenvh
01-10-2010 11:45 PM
