Fault codes, should i be worried?
What ^he^ said. Confirm that the model you're buying includes the JLR package from the manufacturer.
Torque is an engine code reader. The Autel reads all jaguar codes including body and chassis, though only to 5 digits. Also allows for some light programming such as setting seats. Definitely will not be getting better service with the Torque app as I suspect Ian Hawkins long retired and is living somewhere in the Fiji Islands:-)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/980x2000/screenshot_20230113_212158_autel_maxiap200_ec2c615fd1fe6aaf127f2b2cb5dfed2bca79db9d.jpg)
I have been using an iCarsoft LRII for several years and it does a fine job of reading most of the codes. It only provides four-digit codes though. it can reset those codes, I reset codes and turned off my CEL this morning. I always use it with the engine running to ensure sufficient current and not cause low battery related problems.
