First time poster, so pls take it easy!
Received 2,190 Likes
Actually you probobly close by our standards. Which in many times meens you have more time left. But if we let everyone go until they were at 2mm pad material or less. There would be alot of complaints about "i was just here and why didnt you tell me then i needed pads? Now im down to metal and need rotors too. You can give me rotors free!" so........that meens we normally look at pads a gauge wether they would make it till the next visit/service. If close or no then we recommend now.
If you take a flash light you can see yourself most times throught the wheel. Keep in mind that the inner pad is always alittle thinner than the outer youre looking at. And if you have brembo or alcan hiperf brakes theyre very easy to diy if you want. The regular pads arent bad either if you want to mess with it. Im more surprised you dont need rear pads cause they wear faster then fronts on new jags
Wolfy
05-28-2024 08:06 AM
Rlover
03-30-2016 10:04 PM
