Fit dry or lubricant?
Old 01-28-2022 | 03:09 AM
Neville Hobbs's Avatar
Default Fit dry or lubricate?
Should the yellow rubber spring seat in a top mount be fitted dry or with a lubricant? If so, which lubricant?
Old 01-28-2022 | 06:58 AM
kj07xk's Avatar
I don’t think there was any lubricant on mine when I replaced the dampers.
Neville Hobbs (01-28-2022)
Old 01-28-2022 | 07:22 AM
guy's Avatar
guy
Nothing about lubricant in the workshop manual. Also, we don’t expect the spring to rub the seat, but sit securely against it. Adding lubricant makes no sense to me.
The following 2 users liked this post by guy:
Neville Hobbs (01-28-2022), steve_k_xk (01-29-2022)
Old 01-28-2022 | 11:00 AM
Cee Jay's Avatar
Neville, are you trying to create ANOTHER interminable squeak you can't find?
The following 2 users liked this post by Cee Jay:
kj07xk (01-28-2022), steve_k_xk (01-29-2022)
Old 01-29-2022 | 02:39 AM
No!!! Not at all, but that is what has happened.
i fitted a new top mount recently in an attempt to cure a squeak, and stupidly created one by lightly smearing the rubber part with rubber grease which went all gooey and sticky causing a horrid creaking sound.
I think It should have been fitted dry - just checking with people that know.
I live and learn.
The following 2 users liked this post by Neville Hobbs:
Sean W (01-29-2022), steve_k_xk (01-29-2022)
Old 01-29-2022 | 07:31 AM
guy's Avatar
guy
Lol, I went through a similar process. When the squeaks first occurred , I had sprayed lube up there as well. Solved the issue for about a month. Then I said “the hell with it” and changed all 4 corners.
You know, for a 14 year old car, she amazes me at how well built and structurally sound she is…. just keep up with the maintenance. Of course due to age, the maintenance items now exceed what was originally planned. Case in point…
Neville Hobbs (01-29-2022)
Old 02-02-2022 | 04:54 PM
Took the top mount out today, gave it a good clean and refitted it dry. No creak so far!
Also fitted four new rubber bobbin mounts to one of the engine oil coolers as two were broken. 62 bolts had to come out for access!
guy (02-03-2022)
petercz
01-27-2022 04:58 AM
baxtor
05-31-2021 08:12 AM
CharlesHK
05-25-2021 11:31 AM
DavidYau
12-08-2019 08:17 AM
yachtmanbuttson
08-04-2019 12:32 PM
Quick Reply: Fit dry or lubricant?
