Flat Battery
2012 Jaguar XK
I let my battery go complete flat.
I don’t drive it as much as I should and usually keep it on a CTEK trickle charger but didn’t do it this time.
The battery seems completely flat (it’s the original battery). The trunk and doors are locked.
I was able to connect the CTEK to the emergency supplemental battery terminal under the driver side rear fender.
It initially didn’t take any charge but I found a better ground and it started charging.
Once charging all of the lights (headlights, taillights) started flashing and I could hear relays clicking. Seems like it was trying to reset?
I was able to open the doors but not the trunk.
The flashing lights and relay clicking didn’t seem good so I unplugged the CTEK.
What should I try next?
I could try to let the CTEK to keep charging?
I could also call AAA and get a proper jump.
Thanks!
Thanks!
Received 1,975 Likes
I gave it another try and the electronics freaked out, typical low battery. I did manage to open the boot.
I can either try a real charger or get a high amp jump from AAA. Other option if I can get the boot open again would be to swap out with a new battery.
Yep, dug in deep.
Yep, dug in deep.
A CTEK is fine but it depends upon what model you have. Mine is a 10A CTEK smart charger which is permanently connected but also has a 10A supply setting so can be used as bulk, non-smart, charger in situations such as yours where the battery is so flat that a smart charger can struggle to start the recharge sequence.
Richard
I probably could have gone longer if I remembered to but the CTEK back on.
- Best plan at this juncture is to replace. I like Interstate and they are nearby but I will search the forum to see what is recommended.
Should it be the AGM?- XK / XKR Battery Overview and Replacement Thread
- Another lesson is that when the battery is this flat, disconnect the negative until fully charged again so the the electronics don't freak out.
SoCal-LBC (05-22-2023)
George Abitbol
01-19-2021 09:58 AM
gmsclassics
01-27-2018 11:20 AM
Mark in Maine
12-31-2017 06:06 PM
