Floppy Sun Visor Fix!
Old 06-12-2024, 02:34 PM
XKDreams's Avatar
Originally Posted by XKDreams
Glad to hear that. I’m awaiting Amazon to delver my Loctite. I’m going to give the Loctite approach a try before trying screws or rivets.
Awesome recommendations. I fixed my floppy visor.
Before & after fixed:
Before
The separated support
Glued and cleaned in place.
No more flop.
The following 3 users liked this post by XKDreams:
guy (06-13-2024), kj07xk (06-12-2024), ralphwg (07-06-2024)
Old 07-04-2024, 01:09 PM
racerxf12004's Avatar
I went the screw route on this thinking it would be stronger. I used 4 flathead #5 screws. Overall length .700" I drilled a .122" diameter clearance hole and a small .060" hole in the mating side for the screw to tap into. This is a satisfying fix and cost the price of some flathead screws. Countersinking the very top of the plastic will help the screw fit flush. Also, when you drill through the plastic don't apply much pressure. Let the drill do the work and drill slowly-you don't want to drill thru the leather (or suede) on the other side. Set the drill on the slowest setting possible. The overall length of the screw you use is critical. Too short and it wont have enough plastic to thread into. Too long and you could feel the end of the screw behind the material when your finished.
The following 2 users liked this post by racerxf12004:
Cee Jay (07-04-2024), kj07xk (07-04-2024)
Old 07-04-2024, 01:39 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
Originally Posted by racerxf12004
I went the screw route on this thinking it would be stronger. I used 4 flathead #5 screws. Overall length .700" I drilled a .122" diameter clearance hole and a small .060" hole in the mating side for the screw to tap into. ...
Modified Truss Head screws may have been a better choice as they don't protrude up or down, but pretty much totally flat. The flat underside would transfer less lateral forces to the plastic also, by not forcing a cone into the hole.
The following 3 users liked this post by Cee Jay:
kj07xk (07-04-2024), ralphwg (07-06-2024), XKDreams (07-11-2024)
Supercharged81
05-10-2018 09:02 PM
Stamford
01-26-2018 06:39 AM
dtomaso1
01-20-2013 11:09 PM
Wild Bill
12-25-2010 04:01 AM
Fjk
10-20-2009 03:58 PM
Quick Reply: Floppy Sun Visor Fix!
