Forged Vortex Wheels
Hello
i have a 2009 4.2 XKR with Alcon brakes and forged vortex wheels.
I believe that the parts number for these wheels is:
C2P17497 (front)
C2P17498 (rear)
Recently I purchased two vortex wheels, hopping that they are identical apart from the colour/finish:
C2P25174 (front)
C2P25175 (rear)
Can anyone advise me?
thanks in advance
C2P17497 (front)
C2P17498 (rear)
C2P25174 (front)
C2P25175 (rear)
thanks in advance
Hello
C2P17497 (front)
C2P17498 (rear)
C2P25174 (front)
C2P25175 (rear)
thanks in advance
C2P17497 (front)
C2P17498 (rear)
C2P25174 (front)
C2P25175 (rear)
thanks in advance
Google Search of C2P25175
There are 2 versions. The original silver versions WERE forged and had a 26 rear offset. Jaguar re-released them several years later for the face-lift X150 in a cast version, gloss black with machined face, lower price and applicable rear offset for the new E-diff.
The two people with weights both bought them online instead of being OEM.
That said, the same design of wheel; forged vs cast, will weight about the same.
The advantage of forged wheels is not tensile strength, lighter weight material, or stiffness.
The advantage is the forged material can deflect for more cycles without damage and can deflect farther without damage.
This does allow the designer to work to different tolerances in the design when it comes to forces when in use. This is why some forged wheels are lighter than some cast wheels.
However with same design of wheel in either process there won't be an extreme difference in weight.
For a racer running up on curbs and making hard contacts; the difference between a cracked wheel and driving off from a hit can be forged vs cast.
An important aspect of modern low profile tires and their larger wheels is stiffness. This stiffness requires more material and weight.
Everything I have read is that the original 4.,2L XKR-S came with Vortex Forged wheels.
Later a cast version in similar styling came out as a Vortex Cast wheel.
Panthro (06-06-2019)
aholbro1
03-15-2019 03:50 PM
dag82
12-01-2017 05:56 AM
