View Poll Results: What kind of leak is this??
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Found leak in backseat behind Driver's Need Suggestions
#41
@dstrong11 , what are those wheels? And specs if you don't mind. Can't seem to find any nice aftermarket wheels for my 07 XKR. Thanks.
#42
#43
@luv2fly unfortunately, the 19" Tamana wheels pictured in Post #1 won't fit your 4.2L 2007 XK because the rear offset is for the 5.0L XKR with the e-Diff.
See this chart for the OEM wheels that will fit your car.
Stuart
Stuart
#45
Thanks, Stuart. I meant the honeycomb style wheels in post 19. Looks like they replaced the 19" Tamanas. There were several wheels fitted to the XKR with much better styling than the 19" Jupiters that came on mine. My first one had staggered Sentas, but finding a set off an XKR is impossible and new not worth the money. I have 20" Selenas on it right now with 20mm H&R spacers on the rear and they look ok but still don't fill the wells. And many styles have multiple offsets for different cars. So, it's a matter of finding a set with the right width and offset. I have my eye on a set of 20" 9 and 10 wide with the correct offset. Just don't want to spend that much money on wheels, then tires. But if nothing else comes along.... And you reminded me I need check the rear track width, too. Probably whey these Selenas looked ok on the other XK but not mine.
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1847x632/xkr_side_view_1_d757e8040afbb5b656e056a1caa44d59a8e4a4ac.jpg)
Those honeycomb wheels are not OEM Jaguar. According to Google Lens, they're
20" TSW Sebring Wheels and are available from Tire Rack. Scroll down through the link to find them.
#46
.................. Those honeycomb wheels are not OEM Jaguar. According to Google Lens, they're
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/496x247/screenshot_2024_04_03_at_08_09_01_wheels_c378e2a61504c9c2bf4e4c1a5d642f92b10119d9.png)
#47
The reason your Selena wheels don't look right is that they're made for the 5.0L, which is why your needed the spacers on the rear. My 4.2L 2009 XKR Portfolio Convertible came from the factory with Selena's. The suspension has not been modified.
Thanks to you and @Cee Jay for your input. I've definitely been disabused of the notion that wheels off one XK fit correctly on another. At least the Selenas I bought will fit the SV8? Now I'm even doubting that. Some wheel pulling in my future.
#48
@luv2fly What you’re looking for are offsets…. The front offset for all MYs is 49mm @ 8.5”, the rears are 26mm @ 9.5”. Knowing that you can now pick any front wheels 8-9” wide and with an offset of 33mm to 49mm. For the rears 9-10.5” with an offset of 20-29mm.
Here’s a great tool for calculating fitment.
https://www.1010tires.com/Tools/Whee...et-Calculator#
#49
To me 26mm offset may be perfect on the rear of the 07 XKR, but could be 1" inside the fender on a 2013, because of the narrower track on the 13. Offset isn't absolute is what is confusing me. Works fine if I order a new wheel of the proper width with the 26 offset. But, getting another Jaguar wheel with a different offset, I actually have to put it on the car and measure to determine the correct spacer. Am I just diving deeper in the rabbit hole?
Should have kept my first 07. It had the Sentas. But, no, I hadda have a 2013 XKR Special Edition. And it seems no one has a decent aftermarket wheel for the 07. So, I need to try to make a Nevis or Orona work.
Anyway, thanks again. I'll figure it out.
#50
Received 2,020 Likes
#51
Thank you @jahummer for the link. I've used that website before but hadn't see the offset calculator. I've kinda got a handle on it, but the Selenas I bought came off an 09 XK and have a 46mm offset - 20mm spacer which puts it at 26, same as original XKR rear Senta. Still doesn't look right so it has to be the Senta being wider, but the tire is only 5mm wider.
https://www.willtheyfit.com/index.ph...9-5&offset2=47
luv2fly (04-03-2024)
#52
19" Staggered TSW Wheels Sebring Silver with Mirror Cut Face Rims #TSW096-4 (audiocityusa.com)
20" Staggered TSW Wheels Sebring Silver with Mirror Cut Face Rims #TSW096-6 (audiocityusa.com)
#53
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
This link may help you out a bit more then...........
sunchip
08-28-2023 09:21 PM
davidladewig
04-12-2015 03:10 PM
