Found a Uk site that does grooved and slotted rotors.
Found a Uk site that does grooved and slotted rotors and different types of pads. My car came with rear slotted and grooved rotors, so want to replace with the same. I want to match the fronts also.
There is 5 types of disc, which would you choose.
Which pads would you choose.
I see theres 2 front sizes, i think mine are the 355mm.
Brake Discs and Pads for XKR 4.2 Supercharged 06/06-06/09
powerhouse (07-16-2016)
Ordering the disc before the weekend, can someone just confirm that these discs are the right size for my 2007 xkr standard brakes:
FRONT DISC SIZE: Vented Diameter: 355.0 Thickness: 32.0 Minimum Thickness: 30.0 Height: 48.2 Bore Diameter: 71.0 Studs: 5
REAR DISC SIZE: Vented - Diameter: 326 Thickness: 20 Minimum Thickness: 18 Height: 38 Bore Diameter: 64.5 Studs: 5
Found this sit doing black diamond discs, are they better
http://www.europerformance.co.uk/pag...product=154741
powerhouse (08-12-2016)
