Front left headlight intermittently failing
Hi all
Anybody here is familiar with the following headlight issue?
Seldomly - like once a week - the low beam headlight on the driver side does not work. All other lights do work. And interestingly there is NO FAILURE MESSAGE in the dashboard informing about a failed bulb or similar.
Therefore it is only in absolute darkness or when the headlights mirror in the car in front when I notice that the left headlight is off. When I then cycle the lights on/off, the left headlight is usually back to work.
Any ideas??
BR
ter
Any ideas??
BR
ter
Queen and Country (04-09-2019)
HIDs need real high voltage. What's happening is that the capacitor is only partially charging on the first go around, not enough for a power on. Over time the capacitor will only get worse. Caps have a lifespan.
But in this case it seems to be isolated to a less than perfect cap.
Those damn Brits with their fat greasy fingers from the chips, covered in circuit destroying salt and vinegar and only newsprint to wipe with.
guy (04-10-2019)
xenophobe
12-06-2015 12:49 AM
Anfield Dreaming
05-04-2015 12:34 PM
99xk8
12-14-2012 08:55 PM
Dallas4lr
05-06-2008 05:08 PM
