Front ride height xkr 4.2
Ive lost my measurements would someone be able to measure the ground to arch going through the middle of the rim .... looking to see the ride height of xkr 4.2 on standard 20s
Should land somewhere in 705-715mm roughly
Received 2,048 Likes
Probably not exactly the info you’re looking for, but on my 4.2L XK, originally equipped with 19” wheels, but now riding on 20’s, the ground to wheel arch is 27.75”, and the center of the wheel cap to arch is 15”.
The second measurement is probably more useful, as the ground height will be affected by type of tire and inflation.
steve_k_xk (07-22-2023)
Ride Height Factory Specs here Steve
FRONT REAR
Naturally aspirated (NA) 396 mm ± 15 mm 396 mm ± 15 mm
Supercharged (SC) without dynamics pack 394 mm ± 15 mm 393 mm ± 15 mm
Supercharged (SC) with dynamics pack 384 mm ± 15 mm 379 mm ± 15 mm
FRONT REAR
- All the above figures are measured at "kerb" height -all fluids at full and a full fuel tank.
- Tires must be inflated to normal pressure
- Rear thrust angle = (LH toe - RH toe) ÷ 2
- Ride height is measured from the centre of the wheel to the apex of the wheel arch,
through the wheel centre line.
The following 4 users liked this post by Sean W:
Received 1,177 Likes
The following 3 users liked this post by guy:
htrdlncn
04-18-2023 02:54 AM
u102768
02-05-2021 05:57 AM
User 070620
05-06-2019 05:22 AM
