front rotor replacement
I am going to have to replace front brake pads and rotors on 2010 xk soon. would like to get ceramic pads as recommended by bocatrip from RockAuto. Would like to get rotors from them also, they have a few choices, I will have my INDY install them, any suggestions as to which rotors would be best choice. I am not a hard driver, drive car almost daily. thanks
bobdr1 (05-07-2014)
I looked long and hard for quality third party rotors and they don't exist. You can have Spires built you some custom fixed AP rotors on an aluminium hub but they are around 2k a pair. They also have some slotted stock rotors available. If your just driving to work and back and are not aggressive, the stock rotors are more then adequate.
bobdr1 (05-07-2014)
car has 25k on it, front pads are almost gone and need replaced, rotors are grooved and told that they do not turn they rotors and will need to be replaced when they replace pads, getting ceramic pads. I know nothing about rotors, there are a few choices at rockauto.com, none of them that expensive, not sure what I need? thanks again
All four of my rotors were warped after less than 5,000 total miles on the car. The service manager told me this was common as the rust transfer is a factor after the car sits for so long. I had all 4 replaced and was able to start out with fresh rotors and ceramic pads.
bobdr1 (05-07-2014)
My XK will stand for a few weeks and a few rapid stops cleans the rotors quite quickly.
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
Fraser Mitchell
10-01-2015 04:06 AM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
