fuel pressure whats to low? dips to mid 40s
tracing a lean issue and misfires. now the car just misfires on #3 via snapon scan tool with a misfire at startup. I'm presuming its #5 on startup because it doesn't show on the counter but gives a misfire code for #5. strangely #3 is the misfiring cylinder. so my question is what is to low a fuel pressure for proper operation? ive done many things to fix this car swapping sensors bank to bank new fuel filter, inspected air filters, swapped coils, new plugs swapped after since misfire zeroed in on #3.
Could the fuel pump be going and #3 is the weakest injector?
Could the fuel pump be going and junk made it past the filter and be messing with the rt bank as #7 had the issue before #3 after installing new plugs?
also was giving misfires for the whole odd # bank at times with a preference for just 1,5,7 with random. cats passed backpressure test and camera inspection. I've posted elsewhere but this is specific to fuel pressure as i don't want to replace things unnecessary and costly for the customer and frankly this kitty is baffling me.
The best way to correct vacuum leaks is a smoke test. $100 tester from Amazon does the job very well. You'll need an air compressor as well -- the pancake type used for air tools should work fine.
steve_k_xk (01-12-2024)
I fitted a new Fuel Pressure Sensor/Regulator in my 2006 XK a couple of months ago. A cheap part which took literally 10 minutes to replace as it is so easily accessible at the front of the right-side fuel rail under the bonnet/hood and all misfire/fuel pressure problems are now fixed. I changed the fuel filter as well as I had bought a new one but the sensor replacement had already sorted the problem.
Richard
Richard
The following 2 users liked this post by RichardS:
Cee Jay (01-12-2024),
jagboy96
29
06-11-2013 04:46 PM
