Fuel Pump Driver module Location
Per the Manual:
"The FPDM is located on the RH end of the charcoal cannister and is attached by 2 scrivet fasteners."
It's under the vehicle. Not sure if the differential comes into play to gain access as the charcoal canister requires the removal of the differential in order to be replaced.
