Fuse for front foglights.
Received 2,646 Likes
You won't find a fuse.
The Front Fog Lights are protected by the CJB (Central Junction Box). The circuit is protected by FET's (Field Effect Transistors). which can detect overloads and short circuits.
The FET's respond to heat generated by increased current flow caused by a short circuit. On a normal circuit this would cause the fuse to blow. The FET's disconnect the power supply to the affected circuit. When the fault is rectified or the FET has cooled, the FET will reset and operate the circuit normally. If the fault persists the FET will cycle, disconnecting and reconnecting the power supply.
The CJB stores fault codes which can be retrieved using Jaguar SDD.
peterv8 (09-21-2018)
wnlewis
XJ40 ( XJ81 )
02-09-2009 10:47 PM
