Garage floor
Old 10-07-2023, 02:55 PM
Cee Jay's Avatar
Received 5,467 Likes on 3,220 Posts
Originally Posted by Sean W
You live in a fairly arid climate @Cee Jay . too much moisture in the concrete when it was applied? I stained my floor then used a clear Polyurea (somewhat different.) I haven't had that issue. I'm still happy with mine but that's a shame yours is lifting from chemicals.
Naw, it's not lifting, it gets physically eaten by solvents. First I saw was when I dripped some PVC primer, the purple stuff, on it. I grabbed a towel to wipe it up and the top layer lifted up in a pile of goo and it stained the rest that wonderful purple color. I cursed myself a bit, then decided to try some brake cleaner on a less-obvious location.... Yep, I sprayed a small bit then wiped...... wiped up the top layer of clearcoat in another pile of goo. It is still white in that spot, but it isn't as shiny since the clear is gone from there. Hey, maybe it is JUST the clear that comes up. Or not, since the purple stain did lift the clear but also stained the white. Evidently it bonded with it.
Regardless, PA gets eaten so I don't recommend it.
The following 4 users liked this post by Cee Jay:
kj07xk (10-07-2023), McJag222 (10-07-2023), ralphwg (10-08-2023), Sean W (10-07-2023)
  #62
Old 10-08-2023, 08:58 PM
yovenim's Avatar
Banned
Originally Posted by Cee Jay
I just had my shop floor done in bright glossy white Polyaspartic. DO NOT USE POLYASPARTIC!!!!!!! Sure, it LOOKS nice, but it is easily melted with every solvent known to man. PVC primer Garage Flooring Wentzville, PVC cement, ABS cement, Brake Cleaner, Carb Cleaner, Electrical component cleaner.... All EAT Polyaspartic. I wish beyond wishing that I'd used plain old Epoxy instead.
thank you so much for your suggestion
tberg
06-01-2023 07:29 AM
yachtmanbuttson
05-31-2022 06:51 AM
SecretSupercarOwner
Non-Jaguar Vehicles
02-17-2019 05:29 PM
slojotaa
07-30-2017 04:11 PM
RedRider48
03-19-2014 02:22 PM
Quick Reply: Garage floor
