Garage storage for several months
You can do the math, I don't want to.
drboz5750 (12-04-2020)
in general there aren't as many CO emissions at idle as there used to be. iirc it's DI engines that have drastically reduced them. saw a chart somewhere a while back. there's surely other poisonous emissions to be concerned about. there's also the fact that given enough time in a sufficiently closed/confined space, the engine will simply combust all the oxygen and you will suffocate regardless of whether you were poisoned. that said, it's possible the old movie trope of death by closing the garage door and falling asleep in the car would in reality not turn out that way for most cases.
in general there aren't as many CO emissions at idle as there used to be. iirc it's DI engines that have drastically reduced them. ... it's possible the old movie trope of death by closing the garage door and falling asleep in the car would in reality not turn out that way for most cases.
If you don't die from CO poisoning while in a closed garage with the engine running, just give it more time. Or get a smaller garage.
Received 1,179 Likes
#28
In the past I've put my stored cars on stands. This way I can pop selector in 'D' and let stuff move around a bit. No idea if this helps, but in my mind has to be better than sitting for several months. Here in Ohio that could be from Nov-Dec to March or April.
Get everything nice 'n hot, let freewheel in 'D' for a bit, hit brakes a few times, shut off, repeat in a week or three ha
#30
There's good and bad. I learned the hard way not to leave an old car with the suspension "hanging" after a major repairwas put on hold for much longer than anticipated. When I finally put the car back together and let it back down to the ground, it immediately needed several new suspension bushings. A lot of people do it to try to keep the tires from flat-spotting, but suspension bushes are rubber too. Leaving the wheels hanging in storage puts the bushes in an unnatural contortion for months at a time. For longer term storage I just add some extra air pressure to minimize the flat-spotting and my radials have always smoothed out after a few miles. And if they don't, tires are usually easier and cheaper to replace than bushings. If you had an old muscle-car or truck that you could support the solid rear axle on jack stands, that would be reasonable way to facilitate running the engine occasionally without taking it out in the winter weather. However, safely supporting any modern Jaguar off the ground with the suspension bushes normalized might be a challenge.
I had my MG ZT V8 hanging 5 winters and had no problem, the jag is on it's fourth year and so far all good.
I had/have mice in the garage and this way they can't get to the car!
#31
#33
Also just thought of something else. On some independent rear suspension setups, you need to check the angle of the half shafts before you engage the transmission with the suspension unloaded. On like an old Corvette, you can't rotate the wheels with the suspension fully unloaded due to the extreme angle on the universal joints. When I do do anything like check disk runout or adjust the parking brakes, I usually try first to spin them by hand and then remember, oh yeah, I have to raise the hubs back up a couple inches before they'll turn.
