Gear Oil replaced
Gear Oil replaced
Replace rear end gear oil the other day. Really low and no leaks detected. Only purged about 16 oz. of old gear oil and installed 1.25 liters of Valvoline 75-140 limited slip. It was pretty easy. I used a hand purge to remove old oil and with a 3' piece of 3/8s tubing was able to refill from outside by the rear wheel. Worked great. I have done this several times onZ28 and GTO.
CleverName (06-11-2016)
Received 1,125 Likes
I missed about using the ford gear oil. The auto parts store looked up what type and it said GL5. I was not sure if it was limited slip and read somewhere it was ok to use limited slip. Seems to work fine and no problems.
Probesport
06-23-2017 03:20 PM
DanielSWE
03-28-2016 06:22 AM
