Gear shifter does not rise
I have a 2010 Jaguar XKR.
I was air drumming to Def Leppard at a stop light and accidentally hit the gear shifter B) It sank a bit at the time and retracted when I turned off the car. No problems shifting into rear or park. BUT when I restarted the car, it won't rise! It shifts alright though i.e. I can rotate to shift while its still sunk into its caddy.
I am thinking at best, the shifter assembly is dislodged and I can reseat it? and at the worst, I will need to drop in a replacement shifter assembly.
I looked at some threads and looks like I can un-glue the shifter cover, access the center bolt, and mess about in there. Please advise on that. And also will appreciate links to parts website. I am in the US. (Nevada).
Much appreciated!
ps. it was "Animal" by Def Leppard.
Much appreciated!
Welcome to the forums thundersingh,
The Workshop Manual at least explains the two scenarios when the shifter doesn't rise:
If the JaguarDrive selector does not rise from the console when the engine is started, but electrical power is supplied to the selector, the retracted selector can still be rotated to make selections. If electrical power to the JaguarDrive selector is lost, the selector will not rise from the console when the engine is started and the retracted selector will not rotate.
Removal is as follows:
Good luck.
Good luck.
cstanard (09-10-2021)
Don't guess, get the DTCs (Diagnostic Trouble Codes). Read this entire thread, particularly Posts ##5 and 8:
https://www.jaguarforums.com/forum/x...-drive-202654/
Good luck!
Good luck!
Update on this.
I could pop the shifter up but it wasn't holding up consistently, kinda floppy. And today it went into "gear box malfunction". Luckily, I could muscle it into `S` and made my way back home. I think it needs a replacement as suggested by @95 Cat -- any idea where I can order this part?
thanks a lot!
-- Sumeet
thanks a lot!
-- Sumeet
https://www.jaguarparts.com/oem-part...bC12OC1nYXM%3D
Also- where did you order this part?
Thanks!
-- Sumeet
Is this the part/assembly?
Thanks!
-- Sumeet
Thanks!
-- Sumeet
https://www.jaguarparts.com/oem-part...Y4LWdhcw%3D%3D
Update on this.
I could use a heat gun to pop off the lid from the shifter. Ended up scoring it quite a bit but I was like what the heck, if this works, I'll get some fancy new lid. Alas, that wasn't the case. The underlying assembly doesn't rise *at all*. So, I ordered the part with the local Jaguar dealer. It is a $1k part. The good news is that it should be here in 1-2 days. With the fall weather setting in, I will be grateful to have the car operational again.
In the meantime, are there any videos detailing the steps to remove the old part and install the new one?
Thanks a lot guys!
ps I intend to play "Live to Rise" by Soundgarden once this is all working.
Thanks a lot guys!
Received 2,048 Likes
SOLVED!
Thank you all!!
It did cost me $1k in the part and a trim tool as suggested in this thread. Of all the tools this was the most vicious looking and worked flawlessly. There are 8 tabs underneath the trim panel. I went up the right side first and then the left side, the center ones popped out easy enough. I got the schematic from elsewhere on these forums. There are four screws holding the assembly, easy to take out and put in the new part. I had to be a little careful with removing the connector. There's a red tab that needs to be pushed before the connector can be pulled out of the socket. Popped in the new part, the XKR started right up! On the bright side, the dynamic mode etc buttons feel super solid now.
Thanks a lot everyone! Really appreciate the assist!
