Glove box door flopping open
My 2010 XK is having the glove box door issue causing it to drop open abruptly after releasing the open button rather than slowly as designed. I've read some threads about the glove box damper failing which is apparently very common with our cars.
I believe it requires removal of the glove box. I have an Easy Care Gold extended warranty 6 years/72,000 miles of which I have never used even once. It pretty much covers everything other than trim.I have a $50 deductable.Should this be covered under warranty or should I anticipate the dealer giving me any problems? Thanks all.
bocatrip (06-17-2016)
I have the same issue with my 2012. Last time I was at the dealer he said it would be covered under my original warranty and my CPO warranty. He said they need to replace the glove box and he had put one on order. So far it's been 2 months so being that you bring this up I'll have to check with him. You would need to see what coverage you have in your warranty contract because I believe this will be a pricey item.
bocatrip,
jagtoes experience is probably irrelevant to your situation because his car is covered by the original and CPO warranties that are from Jaguar, the manufacturer. Your "Easy Care Gold" coverage is not a warranty because, even though it was sold to you by your Jaguar dealer, it is not provided by the manufacturer. It is an extended service contract that is provided by a third party and is similar to an insurance policy. You should read your contract, particularly the exclusions and limitations. Don't let them weasel out of paying because of some vague and ambiguous provision. But if they do, it's a fairly easy DIY fix from what read on this Forum.
Stuart
Stuart
bocatrip,
Stuart
Stuart
Stuart S (06-17-2016)
Received 1,975 Likes
Yes, fixing the problem is easy, its getting the glove box back in, such that everything lines up properly, is a PIA.
I've taken the glove box out twice, first to fix the floppy door, and a second time to install my ACM, and putting the box back in again wasn't any easier the second time.
If you can get it down under a warrantee, congrats, let them do the work.
isn't there a little spring loaded device on the back of the glove box the prevents the door from flopping open?
I installed my ACM and saw the piece with a nylon string loop that leads out the end of it. I couldn't figure out where the loop attaches, so now I have the floppy glove box issue. Sadly, no warranty and no mention of this in the service manual that I can find.
Both of my XK's had this issue, the first one was repaired under factory warranty. After that car was totaled my replacement XK had the same issue, only this time I was looking for it and had it repaired before delivery.
Funny, on the first XK I noticed that the glove compartment was falling and bouncing so I pointed out that it looked strange to me, the sales guy that was turning the car over to me said that was normal. Despite being the first Jag I ever owned I found that hard to believe so I researched the forum and saw it was a common problem. Since I was under warranty it wasn't a big deal for me, I just had that and a couple of other issues handled before it expired.
Funny after seeing this post I sent a note to my dealer service contact and asked him what was going on with my glove box. He sent me a note back and told me the new glove box will be in in 14 days and we'll arrange to get it installed. I then sent him the TSB number and mentioned this was the fix so either they can do the fix or install a new glove box. Either way it is covered under the original warranty.
Crown in St Pete fixed with TSB repair. One was paid by Jag warranty, the other was out of warranty and a pre-delivery repair on their dime, maybe that is why they fixed instead...
More than likely, the TSB might be a more permanent fix as so many of glove boxes fail. I'm sure Jaguar never updated the replacement boxes as even the later model XKs experience the same failure.
Maybe, but from what I can see in previous forum DIY pictures the plastic piece that the dampener wire connects on breaks. Just drilling another hole in the plastic and reattaching the wire just seems to be another broken plastic part later.
It's a plastic peg in plastic frame that breaks. By using a metal peg (bolt or cotter key) placed in a thicker part of that frame, is a stronger solution, so I think the TSB style fix will last longer than the original.
sharx8 (06-26-2016)
Anyhow, the TSB fix includes drilling a whole in a stronger part of the plastic, and I have not had a repeat failure (going on 2 years now).
And, more important, the fix was pretty easy. I don't have the link (sorry), but some kind person in this forum posted great pictures of each step and captions for the pictures that were easy to follow.
Try it. Very satisfying!
sharx8 (06-26-2016)
I nervously attempted the fix myself (2010 XK), mainly because I don't trust the work of my local Jag dealer (came back for a couple of warranty fixes that included free finger print grease marks, scratches around the plastic underneath the wiper blade, in other words, any warranty work requires my post-cleanup!).
