Got Jaguar a working dealers SDD JLR what can I do with it?
Old 09-05-2019, 07:21 PM
u102768's Avatar
Received 1,490 Likes on 908 Posts
If your car is factory standard then you don't need to download it because the firmware file is already in one of the directories in SDD
I stand to be corrected but if it already has a custom tune and you want to get that tweaked then SDD isn't the correct tool to use because I don't think there is a way to extract the existing tune using that. It is only used to update the firmware.
  #62
Old 09-05-2019, 08:26 PM
AlexJag's Avatar
Sponsor
Originally Posted by tarokyama
Thanks for the information,
I understand how to configure the new module to flash but,
How do I download the file for the existing PCM ?
I'd like to send it in for a tune.
Your complicating things for yourself. If your looking to get a tune I will send you my own equipment , takes less than 10min to read original file, email that over to me, I send it back and you load it the same way. Just getting your original file out of SDD JLR won't make the job easier for the tuner or yourself.
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
  #63
Old 09-08-2019, 12:52 PM
jahummer's Avatar
Received 2,368 Likes on 1,483 Posts
That is exactly how it works. They are stock files on both the PCM and SDD, nothing custom from the factory. If it were to be done through SDD, then the tuner would only need send you a modified SDD file, nothing to download from the PCM.
Most tuners use aftermarket tuning software. It comes down to how well the tuner is able to read and modify all of the necessary tables correctly.
  #64
Old 10-07-2019, 05:14 PM
clubairth1's Avatar
Received 2,351 Likes on 1,851 Posts
Can you let us know how you like the tune?
  #65
Old 10-07-2019, 06:14 PM
AlexJag's Avatar
Sponsor
Not sure who your referring to , but with my tune at nearly 100hp crank gain you can not not like it. The car is a beast!
__________________
  #66
Old 10-08-2019, 09:26 AM
clubairth1's Avatar
I have a VAP tune and gained about 2 mph in the 1/4 mile. Went from 117 mph to 119 mph.
But I have the 5.0L I think yours is a 4.2L?
  #67
Old 10-08-2019, 12:31 PM
AlexJag's Avatar
Sponsor
Yes mine is a 4.2 , in trap speed I gained around 5mph went from stock 13.3 at 107mph up to 12.5 at 112mph
vintageyz (11-17-2019)
  #68
Old 10-18-2019, 09:10 PM
Aarcuda's Avatar
How safe is it? What are your afrs at full throttle? I might be interested here!
  #69
Old 10-21-2019, 01:06 PM
AlexJag's Avatar
Sponsor
https://www.jaguarforums.com/forum/x...-aj34s-224202/
  #70
Old 11-17-2019, 02:33 PM
AlexJag's Avatar
Sponsor
So finally got the engeneering mode enabled . Going through the ccf editor there are so many options that can be changed. Some interesting ones such as shift indicator , performance fan option and many many others. What's confusing to me is for example ABS module and dynamic stability don't even show as enabled or fitted
even though they are on my car...
  #71
Old 11-18-2019, 02:18 PM
DannyJ's Avatar
Sounds great
What is performance fan option ?
  #72
Old 11-18-2019, 02:30 PM
Sean W's Avatar
Received 4,219 Likes on 2,367 Posts
So finally got the engeneering mode enabled.
How'd you do that? I'm curious, no need personally but have read about a few attempts.
  #73
Old 11-18-2019, 02:35 PM
AlexJag's Avatar
Sponsor
Originally Posted by DannyJ
Sounds great
Not sure .I was hoping others who know would chime in.. I sopose it will make the fan kick on more. I can already modify this manually in a tuning file, but in the engeneering mode looks as there are tons of options...
  #74
Old 11-18-2019, 02:39 PM
jahummer's Avatar
Beware that many of the options in the CCF are not relevant to the X150, you will also see options for the JLR range in there, some are more obvious than others...
  #75
Old 11-18-2019, 02:40 PM
AlexJag's Avatar
Sponsor
Simple.. $100
Sean W (11-18-2019)
  #76
Old 11-18-2019, 02:42 PM
AlexJag's Avatar
Sponsor
Thanks Jeremy! I kind of figured...
Any idea why abs and dynamic mode don't show as fitted even though it's a standard option?
  #77
Old 11-18-2019, 02:44 PM
Sean W's Avatar
+1, even when not in E-mode. I haven't used SDD in over a year but there are some recommendations that show up when I run a scan. However, when I check it against TSB, nothing that applies to our cars or my MY so I've avoided some headaches I suspect.
  #78
Old 11-18-2019, 03:06 PM
DannyJ's Avatar
See this
  #79
Old 11-18-2019, 03:15 PM
jackra_1's Avatar
Received 1,756 Likes on 1,327 Posts
I have tried that on two versions of JLR SDD and get so far and it freezes on ZF6HP26 which I did not select to begin with.
It will go thru several screens to that point and seems to be missing some programming code somewhere.
  #80
Old 11-18-2019, 03:57 PM
AlexJag's Avatar
Sponsor
Yes please save yourself the trouble and don't use the method in YouTube video
Quick Reply: Got Jaguar a working dealers SDD JLR what can I do with it?
