Got some High FLow 200 cell cats installed. Need input
So I finally decided it was time for more mods and bought some direct fit 200 cell high flow cats , installed right before a drag racing event.
results : inconclusive
noise : way up at WOT
power: appears to be down compared to stock , trap speed was down compared to runs with stock cats. Butt feeling also telling me car is down on power
Adjusted for the extra flow in the tune with not much improvement
Now I have not replaced the midsection yet and its all stock, but dont think leaving it stock is making things slower compared to stock can it?
I did a temperature test with the infrared thermometer and test shows 100 degree difference between the front and the back. Front is hotter, which tells me by all internet searches that catalytics are bad and restrictive, but Im not sure if this test applies to high flow cats? Can you guys with high flow cats verify this is normal please?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
You cant get legal aftermarket ones
__________________
Isn't oem warranty for the cats like 100k mi and 8 years?
__________________
I agree . The only way I would loose power from the cats is if they are more restricted . So I'm trying to see if it's in the tune or the cats
I put free flowing mufflers on my XK and lost a lot of power, especially down low. I couldn't wait to remove them (reverting to stock) and ended throwing them in the trash...
jahummer (06-20-2018)
There is a difference between a forced induction motor and a NA one, you may have lost some of the necessary back pressure or unbalanced the VE.
13.72 is the best time i have run in an n/a xk which has 100cell cats and tune to suit
also in terms of the xkr by memory cambo ran 13.18 in stock form then 12.8X with 400 cells / x pipe and adjusted tune allowing for more back pressure
Volumetric Efficiency...
VE maps are the curse of modern OBDii processors. The original electronic fuel injection monitored the engine rpm, throttle setting, manifold pressure (MAP) and a temperature or two and determined what fuel dose to apply to the engine based on Speed / Density (S/D) maps which were coded for stock engine component air flow. Throw in a set of heads or different cam which lowered the MAP and the engine had problems due to trying to run richer for the lower MAP. Later EFI engines used mass air meters which could care less what mechanical components were in the engine (within limits) and coded based on air flow. They are what really uncorked performance limits in the early '90's. OBDii is a much more stringent program due to government meddling and like S/D systems it will code or just not perform if the actual performance doesn't match the 'assumed' performance. To me it really was a step backwards for the home grown builder.
Received 2,190 Likes
Now Check engine light occasionally comes on for cats inefficiency , bu this is expected for high flow cats.
Now can anyone with high flow please confirm if the temperature test is still valid fo high flows cats or is it supposed to be reversed as in my case where inlet is 100 degrees higher than outlet?
__________________
Stuart@VelocityAP
07-09-2021 02:18 PM
jag79
10-14-2010 05:44 AM
rocklandjag
09-24-2010 10:07 AM
