'The Green Turtle' or 'Lets Fix This Junk'
#701
Yeah, ignition coils. Did a banzai run and got a restricted performance going through 140 at WOT. Only code was for #8 misfire. I've also noticed the mileage dropped off a couple tenths the past month so it's time. 157k on the clock too...
#703
Received 1,125 Likes
Very happy to see you contributing again @Ranchero50 !
from some of your work I had planned to get to work on mine... with input from your thread. but with this lockdown in effect I’ve had to set my accommodation on the other side of the planet.
Looking forward to seeing the new speedster at work! That’s no crisis in my books.
The following 2 users liked this post by guy:
Ranchero50 (05-09-2020),
Sean W (05-09-2020)
#704
#705
I'm coming back to the last post on the differentials from June of last year. I'll repeat, it's something I don't focus on much and have never moved away from stock on any car so haven't educated myself.
I would like an LSD but will not spend up for a Quaife. Can you update us on what your goal is now and where you at? Like others, I'm glad you're back posting.
I know Steve_K_XK has swapped differentials (not to LSD that I recall). I got to imagine Jahummer's looked into this too. And I think Cambo has posted something to that effect but I can't find it. So I don't think there's an LSD option outside of Quaife but since you're digging, is it one of your goals to go LSD?
#706
The following 3 users liked this post by SinF:
#707
![Wink](https://www.jaguarforums.com/forum/images/icons/icon12.gif)
#708
#709
So today was mostly a bust. I have power to the pump but also 350k of resistance across the motor leads so it's replacement pump time. For those who are curious if you remove the plug on top of the aftercooler and you don't get coolant coming out with the engine running, your pump is dead...
I did swap the coil pack on #4 and #8 with ones from my spare engine. #4 because Jag doesn't label the cylinders like Ford does. Ford coils though so dirt cheap.
Also need gas shocks for the hood. Vise grips saved the day but...
guy (05-11-2020)
#710
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Okay, dumb question time... What is the part number for the lower shock mounting bolt bushing on the front suspension? My bolt has eaten through it... Found the bolt, C2P7192
I did install the Mercedes pump last weekend. Bit of a fiasco as I took the heater core pump off first (even looked at the manual beforehand). For whatever reason the original pump worked when I powered it up off the car. I think the problem was how I had the connector routed next to the oil cooler line and it had some oil there. The Mercedes install wasn't too complicated beyond soldering the old leads to the pump terminals and filling the void with RTV. Seems to be working.
Now about that bushing...
#711
#713
u102768 (06-06-2020)
#715
A friend of mine presses all his bearings, bushings, and hubs. Every time it is an adventure, but no casualties so far. Last weekend we had to bring out the torch and sledge but it worked out in the end. I always buy complete assembly. With my luck, if I try pressing it in, it will catch fire ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
#716
Thanks gents, this looks like a winner from the Uk for $30.
https://www.ebay.com/itm/FOR-JAGUAR-....c101195.m1851
I might spend more for the silly bolt...
At least now I know why I was getting the odd shimmy from the front end on right hand sweepers on the interstate.
The following 3 users liked this post by Ranchero50:
#717
Ranchero, GREAT thread. Thanks.
Saw earlier you were looking to replace your coils. Which did you use? On the 4.2, the Hitachi AGC1967 are listed as OEM in some places. Also, the NGK 48927 is compatible. Don't really know which are OEM, tho.
Many years working on BMW's -- Lemfoerders were stock and had the rep for best wear on non-poly bushings. Have you found something better for a better cost in the D2P Ebay parts?
Again, thanks! Great stuff.
#718
I did replace the headlamp bulbs with eBay Chinesium knockoffs for a couple bucks. Had to realign the lamps for correct light output and one oddball thing I noticed is that for some dumb reason the adaptive headlamps turned themselves on. So I get corner markers below @5mph and the inside lamp swinging above that.
#719
Ranchero50 (03-17-2021)
#720
Hi Richard,
Long time, no see! Glad that you're back, and hope that all is well!
For me, the feeling of satisfaction I get from successfully fixing something far outweighs the time, money, and effort involved. It's a WHOOPIE, I DID IT! moment. And a great excuse for a cold one!![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
One example was when I installed WhiteXKR's remote control top kit. I thought it might be above the level of my ability, but Steve's outstanding instructions made it possible. It's overcoming a challenge, sorta like climbing my own Mt. Everest.
Stuart
Stuart
