H&R lowering springs cats fault
sherbercars (01-13-2015)
sherbercars (01-15-2015)
I recommend everyone go out a buy a low cost "code" reader . You can get them at most auto parts outlets or on line. They read all generic codes and you want to make sure you get the type that has an "erase" feature which allows you to delete the code. ACTRON is a brand so just look them up. There is a connector under your left knee on the dash where you plug in this reader. It will link up to your management system. I have found that at times sensors due to weather or other conditions trip the MIL but is not a real problem. Erasing the fault will either fix the glitch or if it comes back then you know you have a problem. It also gives me an indication as to the problem so if I can't fix it I know what the dealer will be looking to do.
The following 2 users liked this post by jagtoes:
macon6500 (01-04-2016),
Aus V8S
11-13-2015 11:01 AM
FS[NorthEast]: HOT Black/Black '07 S-Type R w/55k miles for sale!
08Z06
10-24-2015 05:46 PM
Tar
09-06-2015 11:24 AM
