Hard reset
Yep as Cee Jay says, it's a common practice and recommended by Jaguar under certain conditions. No need to worry as this is what it does. A ‘hard reset’ restores the control modules to their base conditions assuring that network communications are synchronized.
When resetting the battery (hard reset), disconnect both battery leads and touch them together to fully discharge all control module capacitors.
NOTE: A hard reset does not repair a fault condition. It simply brings all control modules back to their baseline condition. If a hard reset eliminates the symptoms, then further diagnosis is needed to determine the cause of the conditions, i.e. low battery causing a single control mod- ule to come off line temporarily.
Tony Vasquez (03-18-2022)
1) Using Jaguar approved software
2) X150 Vehicles
- Due to the window drop entry feature, the following procedure should be followed to prevent door seal damage.
- Open one window fully or open a door
- Disconnect the negative cable of the battery for at least 120 seconds
- Reconnect the battery negative cable
3) Same as 2 above except remove both Negative and Positive cables from the battery and touch the cables together. Do NOT touch your negative cable to the positive post of your battery.
The following 5 users liked this post by Sean W:
arenaej (03-11-2022),
Boga (03-11-2022),
dmchao (07-03-2024),
ralphwg (03-12-2022),
YES - as stated above, most of us will have done this at some time.
However, WHY do you want to do this and WHAT do you hope to achieve? It will eliminate all 'learned' settings and reset them to default by discharging the capacitors BUT it will not magically clear troublesome error codes.
Yep, and the EVAP part may take up to 200 miles to reset. Lucky for me, Utah allows one "Not Ready" to pass inspection.
The reset question was mostly out of curiosity. My current issue is still with the convertible roof. I'm able to clear the "front latch" error msg however, when closing the roof automatically, it reaches the front latches then starts to click continuously as if the cable is jammed somewhere and slipping < this is my best guess> . Does anyone have experience with this sort of situation?
XJFanMatt (08-22-2023)
I still have bad memories about this. My X308 4.0 had a bad lambda sensor. I replaced it - having disconnected the battery - and then presented it for MOT, which it failed on emissions of course. But I'd got myself into that position where the tax disc ran out at the same time as the MOT so I couldn't renew the tax. So I had to drive it untaxed to get the engine management to re-learn. I went to a studio to do a day's work. While I was there the car was clamped for having no tax. I had to hang around for several hours and then pay several hundred quid to get it unclamped and the fine paid so I could drive it home again. It passed emissions the next day though. I learned to never have tax and MOT expire at the same time...
