Has anyone replaced the rear lower strut bushings
I'm ordering rear upper and lower control area and stabilizer end links. Going with Mevotech. I noticed the lower bushes on the strut looked pretty haggard. I'm thinking might as well replace them but I don't want to mess up the strut. Has anyone pressed them out? Can it be done in situ or will I need to remove the strut (yes I'm lazy).
Thanks for your help.
Part number for the bushes are URO - C2D4013
I considered this when I did my control arms. Passed it up because I didn't want to buy a whole press kit and try to find the right size adapters. Also my bushings were still OK.
I don't see how you can replace them while the struts are still in place. An extra 4 nuts from the top will let you remove the whole thing. Then you can check the spring and seat for any wear/damage.
Sean W (04-12-2021)
dauraf
06-21-2019 09:30 PM
XxSlowpokexX
12-03-2015 05:18 PM
XxSlowpokexX
11-17-2015 12:22 PM
otisbd
09-17-2013 05:34 PM
