headlamp
Received 2,646 Likes
The following 3 users liked this post by NBCat:
Robert Wagner (12-20-2019)
The manual says to have the beam alignment checked after removing the headlight unit, but I never have and there seems to be no problem. Just check them at night and make sure they are aligned OK. I think that is what the little plastic locator is for - to ensure the light goes back exactly where it came from.
EDIT: Yes, thanks buddy (see below) - I forgot to mention removing the washer hose! Although it's obvious when you start the dismantling process I guess.
The following 2 users liked this post by barnsie:
Robert Wagner (12-21-2019),
winstonsalemncxk (01-04-2020)
There is no need to remove the front bumper. Remove three bolts, remove headlamp washer hose, slide unit towards front of vehicle and disconnect wiring loom.
