Headlamp Question - 2009 XK
The headlamps on my XK work fine in terms of lighting up (although they aren't the brightest, as many threads have pointed out); however, they have melted spots in the top, inner corners of the housings (I'll post pictures when I get home). I want to replace the housings, but I don't know if they are adaptive or non-adaptive. When I turn them on, they don't flick up and down or side to side - perhaps the auto-leveling feature isn't working.
Anyway, other than how the lights calibrate when they come on, is there any way to tell by looking at them if they are adaptive or non-adaptive? They do have the separate cornering lights that turn on with the indicator or while making sharp corners.
Thank you.
Thank you.
I don't have adaptive on my XK but my experience with them on my other cars is that when first starting the car they move in each direction to establish their limits. On all XK models though, the auto leveling should be activated at start up and you should see them move to the up/down limits.
Others with adaptive should be able to respond with more accurate detail.
DlsXK (08-20-2018)
From the outside they all look the same so you would have to look at the back side to see if there is an additional motor to drive the side to side motion. It is easiest to test them in a garage where they would come on automatically so you could see the light pattern on the wall in front of you.
The following 3 users liked this post by Ranchero50:
Those melted corners are from sitting with your turn signals on for too long at night. The cornering bulb gets hot and wasn't intended to stay on for more than 20 seconds or so. Once someone get behind me in a turn lane I turn mine off unless I'm first to turn against oncoming traffic.
scm (10-29-2018)
I don't think the hazards turn on the corner illumination like the turn signals do (and steering input at low speeds)
Received 2,192 Likes
if you have adaptive that are not working you will get a headlight warning icon in the instrument cluster that flashes. I you have the adaptive cornering lights, when driving slowly at night say towards a building that you can see the beam on. Wag the steering wheel. If adaptive cornering light, they will wag also.
Thank you.
Thank you.
I don’t think the adaptive headlights calibrate unless you have the lights set to Auto. They don’t on my UK model.
I am sure this has been discussed before on this forum or the UK one
winstonsalemncxk (08-23-2018)
Sean W (10-29-2018)
Just keep in mind you may have to use some resistors if you do change turn signal bulb to LED, to keep from triggering bulb out warning...
Sean W (10-29-2018)
Well left turn blinker fluid at least. I'm pretty sure Jaguar has different viscosities in the left v.s. right, at least here in the U.S.
Maybe we should start another post to get feedback on the Jaguar recommended blinker fluid specs.....
