Headlamp Washers Not Working
Good evening everybody (it's evening here...
The headlamp washers are not working in my '07 X150 (18K miles). The pump runs perfectly on the bench, but not on the car.
I'm wondering where to start fiddling with it first. Is there by any chance a relay, in the Power Distribution Box, which is the last component in the circuit before the pump itself? If so, can anyone tell me how to get at said Power Distribution Box? I can't find it in the Workshop Manual...
Orthodixie (07-25-2018)
How are you at reading wiring diagrams?
Download it here (free)
http://www.jagrepair.com/images/Auto...79toB09096.pdf
Search "powerwash" and you should see it.
I don't even get the initial squirt when I try to use them the first time. I'm hoping it's just the fuse or relay...
OK, I reckon can find the Power Distribution Box, and Fuse 04, no problem. Is it apparent which is the headlamp washer relay once I get in there?
They should have the relay named (probably abbreviated) and the relay number. I believe the relay numbers are embossed on the box but not 100% certain. Sorry, I've never been in my FSJB and I've never found a relay schematic, just the fuse schematic.
http://www.jaghelp.com/2015/02/jagua...on-and-id.html
