Headlight help
Headlight help
I have a 2007 Jaguar XK my front passenger headlight works fine and the directional bulb works also but the all the bulbs inside the headlight do not my daylight running bulb is not working and my directional cornering light is not working is there a separate fuse for this, when I opened up the headlight the wires inside all frayed in the metal was exposed, two wires with touching so I figured this had to short out somewhere along the line I haven't had any luck looking for a fuse that just handles these couple of Lights thanks
Has anyone ever seen oxidation on the INSIDE of the lens? My headlights are a bit foggy, and it looks like I can see some bubbling on the inside of the lens.
Considering using a restoring kit on both sides of the lens, but I don't see many others having had to do this before.
waltnich
05-02-2019 09:40 PM
TomR166
01-05-2019 02:26 PM
Beagle
12-04-2015 02:27 PM
Anfield Dreaming
05-04-2015 12:34 PM
jagosaurus
10-03-2012 01:51 AM
