Headlight Lens Flaking
Has anyone ever encountered what appears to be a layer sort of flaking off the headlight lens? I just noticed the condition while doing a through cleaning today on my 12 vert. It only appears at the edges of the lens but feels rough and crazed along the upper edge. I can't tell if this is the result of some kind of coating applied by the PO or if the plastic itself is failing.
The good news is this is only present along the edge and not readily noticable.
Those don't yet look nearly as bad as mine did (do zoom in), and they were restored very well (for 150 €/pair).
Those did look pretty bad. It does take a close look to see where mine are flaking off but they are rough when you run your hand over the area. I talked with a shop that said they can restore them but do not see the need to recoat with a UV layer. I think I'm going to skip that shop in favor of one who also feels they need to have the UV reapplied. It is not a killer issue to me right now so I'll probably just wait a while before having them refinished.
Looks like someone perhaps wiped your hood/bonnet with a solvent soaked cloth that touched your polycarbonate lens.
Acetone, mek, lacquer thinners etc.will destroy polycarbonate plastic very quickly.
You were very lucky that the marks were not too deep to sand out.
PC definitely needs a UV coating of some kind.
Bob
Bob
This is a fairly common problem. I’ve been told it’s the UV protection clearcoat that cracks and doesn’t affect the underlying plastic lens.
Options include replacement headlamps which are expensive and difficult to source, sanding off the clearcoat and refinishing with new clearcoat or covering with PPF and dealing with the unsightly look of it but preventing further cracking of the existing clearcoat. (What I did)
I’ll probably have my lens refinished if/when I grow tired of seeing those lens.
Here are mine for reference.
Mine has a slight beginning of this crazing. I already covered the headlights and tail lights with a heavy UV 10% headlight specific tint. It matches the paint great and barely diminishes the lumen output that was already great to begin with.
Can't see the crazing any more and the UV tint will protect what's left.
eBay, although I don't know which brand it was.
Sort of like this, and there are a TON more colors than there was available when I did mine five years ago...
Headlight Tint ideas on eBay
MarkyUK (04-09-2021)
