Headlights and other lighting questions
I am a newbie to the wonderful world of Jaguar having spent 30+ years driving Saabs. I have modified the lighting on my Saabs with additional driving lights and back-up lights -- all relay switched -- by simply tapping into the existing circuits to power the relays. This method has not overloaded existing circuitry and has had no impact on the working of the car's computer. However, I know NOTHING about the Jaguar wiring and the quirks of the electronics.
When I first drove the XK at night here in dark and rainy rural Oregon, I was distressed by how difficult it was to see and so I am looking for ideas for improving night lighting performance.
Because the air is so moist here in the winter, the 6000K HID lights scatter badly creating a visual "haze" and limiting visibility -- That can likely be partly solved by swapping out the bulbs for 4300K . The 4300K colour penetrates moist air better and cause less dazzle for other drivers which should help -- but I would like to add some sort of high intensity pencil beam lights (4300K or lower) for night driving OFF the freeway.
My lights are aimed higher than I like them and may be causing dazzle so I need to adjust them downwards -- but I read a post that suggested it was an electronic adjustment rather than a simple mechanical adjustment at the headlight assembly.???????
Has anyone got experience in modifying the lighting, or adding additional driving lights? What are the mechanical/structural challenges of adding driving lights to the front, and how does tapping into the existing wiring impact the computer -- if at all? If the computer in not affected, the back-up light is an easy fix with a relay switched LED light bar under the rear bumper . . . . but I cannot immediately see any easy solutions to improving the driving lights. . . . . .
Thoughts, suggestions, caveats?? Many thanks.
The following 2 users liked this post by Bill400:
guy (01-12-2022),
tompullizzi (12-10-2022)
Received 1,177 Likes
I concur. The factory light leveling is a tad high for me as well…. that why I lowered the beam ever so slightly. Do you have the adaptive lighting? I find it very good.
And about the “yellow fogs”. I purposely use the Sylvania fog vision bulbs … in yellow. I suspect you see as much fog as I do. And the colour cuts very nicely through snow as well. I purposely raised the beam of the fogs very slightly to 1 degree below horizontal.
Kiaorana (01-12-2022)
Thanks Guy. I had not thought of putting the amber bulbs in the Foglight -- what a great idea!
Unfortunately, many people equate "bright" with good illumination -- not realizing that our eyes are sensitive to blue light and see it as "brighter", and not realizing that it scatters in moist air, rain or snow and that the illumination on the road is far better with "cooler" light temperatures and that 4300K white and 3000K amber lights penetrate MUCH better. In fact, when I was younger, France required low beams to be amber and not white. (I am probably really dating myself :-)
Thanks for putting in the diagrams -- unfortunately the Allen head screws are not visible on my car so I shall start disassembling things until I I find the adjustment points. I am a newbie to the XK after 30 years and three quarters of a million miles in Saabs. So armed with my trusty "Haynes" manual I will jump into almost anything on a Saab -- but I am much more tentative on the Jag. I really don't want to screw anything up that will cost a fortune to fix later. LOL. Finding what I need in the Service Manual is challenging at this point -- it is a vast tome -- so I am moving slowly and carefully. LOL
I am also considering adding a LED light bar - a curved bar light bar could fit nicely just in front of the lower grille without protruding unnecessarily and an amber spot/fog combo might do the trick. Still brainstorming and exploring.
Thanks for the feedback and helpful input. Andy
Looks Good! That looks like the 42 inch.
I have the same issues with my Saab -- with an array of high intensity halogen, lights I have to turn them off whenever I am following someone (even a mile or more away) or any time there is oncoming traffic. (they are keyed to my high beams anyway) HOWEVER, the times I want them are on the back roads coming back from evening meetings where I may meet 3 cars in a 40 minute drive -- they are ideal then.
Driving in traffic on the freeway is not an issue, even with the basic lights, but dark, winding roads in the rain . . . . . got to have something better! :-)
Kiaorana (01-14-2022)
guy (01-14-2022)
I put in fairly bright LEDs, at 6000k because I use the foglights exclusively as daytime driving lights here in South Florida. Never on at night, and very visible during the day.
The weird little W5's in the headlights are good for decoration but not much more.
I like using DRL's, but prefer to choose when they're on.
Kiaorana (01-15-2022)
Navionsam
05-21-2012 04:37 PM
