HEADLIGHTS on RHD cars
Received 2,677 Likes
Therefore, the reverse is true in a place that has a 'stay right' rule.
DrG (10-28-2017)
Have a read of the postings on this thread concerning the headlamp warning indicator prior to spending money on a new headlamp assembly:
https://www.jaguarforums.com/forum/x...-187506/page2/
Considering the cost I'd talk to someone or just do it your self and take the lens off. it's glooped on with gummy rubber that will loosen with heat. I pulled one of mine off and found a broken wire. Took the better part of a day to pry it apart and fix. Pics of the guts are in my build thread.
Also, swap the lamps side to side as well as swap the control modules (on the back of the lamp housing) to ensure it's internal to the lamp vs. a chassis or module problem. again, check my build thread.
NBCat (10-28-2017)
Cee Jay (10-28-2017)
Hi all,
Because I am intermittently also getting the AFS warning light with the left headlight parked down, I recently had that headlight out for inspection.
In particular I wanted to check that this lever to change from LHD/RHD is in the correct position and not loose. However I could not locate this lever at all in my Swiss 2011 car’s left headlight. Any clue?
Br
ter
Br
ter
