Heat shields dissolving...
Noticed another of my heatshields (2010 XKR) was loose at the weekend, this time the one below the fuel tank. This has happened a few times on the different shields, usually they dissolve around the holes where they're fixed to the car. I'd obviously "fixed" that one before as when I took the nuts off the studs on underside of the tank straps there were fairly large nylon washers there, I remember putting these onto a number of the fixing points for heat shields a year or so back when changing the exhaust mid section.
I've changed those washers for larger ones for the time being but clearly it'll just happen again so I got to thinking about maybe ditching the OEM heat shield and replacing it with some sort of self-adhesive heat-resistant tape or mat. Has anyone done this already and if so, how did that work out? I live in Scotland where it is known to rain from time to time so that may be a show-stopper...
When I got my old 4.2 XKR it didn't have the rearmost heat shield at all, the one above the rear silencer. I didn't replace it for a couple of years, until I was swapping to an aftermarket silencer and I had no issues with that shield being missing. That's right at the back of the exhaust system though, I would imagine the further forward you move up the pipes the hotter they'll be. Given that this shield is right under the fuel tank I guess it's probably desirable to have one in place there?
In anticipation of having to change these at some point too, did you have to drop your middle exhaust section to change that shield out?
8bit (06-26-2020)
I didn't take a photo with the centre section refitted so can't be absolutely certain where that black patch was in relation to the resonator.
Note in the comparison photo in post #11, the shields are facing in opposite directions. There is a recess stamped into the new one corresponding to the location of the mark on the original.
Yeah I spotted that the old and new shields were oriented the opposite way round; looking at the second photo in post #5, the holes in the horizontal sections where the cross brace under the exhaust goes seems to line up with the dark patch. Looking at posts #5 and #9 that dark patch would seem to roughly line up above the rear resonator and below the center join in the prop shaft.
You may try to fabricate a large washer using similar material like here
https://www.ebay.com/itm/163918900550
OUScooby
06-25-2019 08:42 PM
lickahotskillet
03-15-2018 08:58 PM
