Heated rear screen button on when starting.
Just though i throw this question out there. Lately when i start my car the rear heat screen button comes on. I press it off and it stays off. It keeps doing this when i start the car any time. Any answers and before anyone says anything , it's not a battery issue. it's 100%.
powerhouse (02-05-2015)
Had thought about that, maybe this is why, snow and frost here this last few weeks, bitterly cold, good call. Will keep an eye and see will it stay of when the temp goes up.
Yep same happens to me, its just built in, its useful though sometimes it does get it wrong when the temperature is low but there is nothing to clear. So its just a guess made on the temperature
Yes, this is an automatic feature; the mirrors also are heated automatically, and the front windscreen if your car has this feature.
Now, if you use your XK in winter conditions and for relatively short runs, you can understand why the battery discharges! If you have a garage with electrical source, a CTEK battery maintainer is the cure for any electrical issues caused by low battery voltage (and the symptoms are varied and random).
powerhouse (02-06-2015)
That sounds right with the 5 deg C, mine seems to come on automatically around when it's 40 deg F out.
I find it annoying more than anything as my rear window has yet to be fogged up. Even this afternoon I left a customers plant and it was 11 deg. out. Rear window was clear even though outside for 8+ hours.
Also wonder if that's part of the cause for the rear window separating on verts. Seen a few posts in the forum about it. I know there isn't a timer on the defroster as mine doesn't shut off unless I do it manually. All I do know is every time I start the car the first thing I do is shut off the defroster as it's winter here.
The following 3 users liked this post by Ngarara:
trosty
26
12-18-2022 06:40 PM
