So we had the first frost of the year last week and it was the first time I used the heated windscreen. Worked really well, on the drivers side only! Anyone else had this problem?
I had a similar problem on my Range Rover after it was hit by a small stone.
Any good electrician can check the wire connectivity.
There are two connections on each side of the windscreen.
