Heater gets weaker after approx. 20 minutes
Hi all,
In my low mileage 2007 XK the heater heats perfectly well, but after driving for about 15 to 20 minutes, I start to feel slightly cold on the left leg and need to increase the heat level 1-2 degrees.
Same thing whether AC on or off or with “Auto” enabled or not.
Any clues? Someone has similar issue?
Suspect:
Could it be a faulty internal temp sensor equipped with small fan (located behind steering wheel)?
Somebody replaced this temp sensor themselves?
br
ter
Suspect:
br
ter
First step should be to get the DTCs (Diagnostic Trouble Codes) so you're not shooting in the dark and wasting time and money bt trial and error. Your initial suspicion may be right, and the DTCs will confirm that.
Try setting your climate control to recirculate and see if that makes any difference. I presume that you have checked for any coolant loss and that's OK. This thread might be helpful:
https://www.jaguarforums.com/forum/x...stency-117433/
Ter11 (02-11-2020)
Turn on and off air recirculation and listen for odd noises as the initial diagnostic step.
Ter11 (02-11-2020)
Did you use a code reader that is capable of displaying climate control codes? I'm pretty sure that the inexpensive ELM327 bluetooth readers that use the free Torque app don't have that capability, but I might be wrong.
Sean W (02-12-2020)
Hi all,
This is a problem mostly noticeable during Central European winter.
When I set a specific cabin temperature that is comfortable during the first ca 15-20 minutes of the ride, I need to add 1-2 degrees afterwards as I start to feel a bit cold in the leg area.
Then, when I get to destination and park the car without touching the temp settings eg. overnight, the next day after driving less than 5 minutes, I need to take the temp settings 1-2 degrees down again to avoid feeling very hot. And after another about 15 minutes it starts all over gain, ie. add 2 degrees to not feel cold...
Futher observations:
- The cabin sensor often makes a low buzzing noise, which is only noticeable with ignition on and engine off. It makes the same noise with engine on, but then not audible due to engine sound.
BR
ter
BR
ter
But if constant heat is desired, the process is simple: push the red heat arrow until it gets to maximum heat. Now you just adjust the fan speed to your liking, the system will continue to put out full heat until your toes burn. Note that it is NOT faster to reach a comfortable temperature this way than simply setting the control to your preferred temperature.
You have hit the nail on the head; this is a climate control system, not a heater/air conditioner. You set the cabin temp to the final temperature at which you want the cabin. It is perfectly correct and normal for the system to blend cooler air into the air flow as the cabin temperature approaches the set temperature. It will then contune to blend the cool and hot air to maintain the set temperature.
br
ter
